TwinTurbo.NET: Nissan 300ZX forum - Re: I remember an old NA of mine would want to stay
Da Flash
on June 04, 2013 at 11:31 AM
posted by 300ZMang
on June 04, 2013 at 08:39 AM
Throttle bodies were cleaned and I cleaned the inside of the plenum as far as the toothbrush would reach. The TPS in set to 0.42v and the closed switch is on. What was it that you found on the NA that was causing the high idle??
High idle, ~1100rpms with aac plugged in, ~700rpms without
Da Flash
18:28:28 06/02/13
I feel your pain... have you done this:
Medallion Man
04:17:13 06/03/13
Re: I feel your pain... have you done this:
Da Flash
08:56:02 06/03/13
so have you adjusted to IAA by the screw?
Medallion Man
10:54:59 06/03/13
Re: so have you adjusted to IAA by the screw?
Da Flash
11:45:21 06/03/13
NDS isn't the true timing...
Medallion Man
03:29:42 06/04/13
Re: NDS isn't the true timing...
Da Flash
20:43:11 06/05/13
Perhaps it's an issue with your ECU? (n/m)
300ZMang
11:23:08 06/03/13
Re: Perhaps it's an issue with your ECU?
Da Flash
20:57:17 06/03/13
300ZMang
08:39:39 06/04/13
Re: I remember an old NA of mine would want to stay -
Da Flash
11:31:45 06/04/13
It was too intermittent for me to really care, as I was
300ZMang
13:37:24 06/04/13
Re: It was too intermittent for me to really care, as I was
Da Flash
10:20:29 06/05/13
Re: High idle, ~1100rpms with aac plugged in, ~700rpms without
Da Flash
15:19:35 06/06/13
