you need to get a timing light to view the real timing. mine showed a perfect 15 on Conzult, ecutalk and another program but that is what the ecu thinks not what the engine is actually set at.
you also have to make sure that in setting the IAA it isn't fully in out out as that isn't the way it is supposed to work and would indicate another issue.
