What could be the issue here? While the car is off and the headlight switch turned to off the left hand high beam headlight will flick on ALL BY ITSELF and the turn off RANDOMLY ALL BY ITSELF?
All I have checked was for lose connections and the relay in the main fuse box in the engine bay. Is there anything else I could check? Maybe grounding points? Where are they? Are there any other fuses or relays I should check?
Any information will help thank guys!
LH High Beam RANDOMLY comes on and off!?!? - Terayonneo20:57:10 06/03/13
