TwinTurbo.NET: Nissan 300ZX forum - UPDATE - bad transmission sub harness
Subject UPDATE - bad transmission sub harness
Posted by ricktek on June 02, 2013 at 7:28 PM
  This message has been viewed 485 times.
In Reply To Auto transmission temp sensor....need to replace? posted by ricktek on May 31, 2013 at 08:46 AM
Message For future Z-fans that experience this problem - here is the latest update....
Z1 sent me another temp sensor (part of transmission sub harness for solenoids - so it has to be cut and spliced in trans pan - under control assembly.
I suggest doing a series of electrical tests - the on service manual is great...pages AT-58 and 59.
You cannot test temp sensor without cutting the wires - there is no connector even though shop manual makes it sound like there is.
As for my status - I started the sensor swap by doing one more electrical test on the sub-harness from trans to connector E-24 connector. After removing exhaust - I added test wire and cut into insulation for circuit test. The circuit from E24 (pass-eng compart) passed. This was from connector down to white protective sleeve on the harness where it enters the transmission body.
Based on data pointing to a failure somewhere within the transmission – I removed the trans pan.
I first ran the OHM test per the Nissan manual (Page - AT-87) on the new temp sensor – and it was in spec. I removed the installed sensor from trans and ran the same OHM test – it passed.
This led to an isolated wiring failure between the terminal cord assembly and the first 3 inches of wire within the transmission. I ran a resistance check across both wires (wires 33/35) and wire 35 FAILED.
Since the sub harness has connections to 5 solenoids, multiple connectors, and the temperature sensor - and also has a bulk head fitting (terminal cord assembly) – this is not in a serviceable area and will require a new sub harness.
This requires removal of the control valves assembly - and I am not cool with that. I am talking to Z1 about a transmission replacement as this beyond my comfort level and I have done enough. Hopefully - they will do what is right.
I will post final outcome.
