TwinTurbo.NET: Nissan 300ZX forum - brake lights stay on? bad brake booster?
Subject brake lights stay on? bad brake booster?
Posted by doanh on June 01, 2013 at 8:54 PM
  This message has been viewed 336 times.
In Reply To weird brake problem - follow up posted by doanh on May 30, 2013 at 11:59 PM
Message tried bleeding the system again today, got a friend to help. got some more air out..
still the same problem but i noticed the brake light stays on for quite a long time after the car is off and no one is touching the brake pedal..
even after I disconnect the vacuum line from the brake booster. which leads to this question..
if you remove the vacuum from the booster, should brake pedal return to normal position right away? since the vacuum is gone?
