TwinTurbo.NET: Nissan 300ZX forum - clutch adjustment
Subject clutch adjustment
Posted by ouikikazz on May 30, 2013 at 4:56 PM
  This message has been viewed 170 times.
Message setup: rps carbon carbon/ z1 shifter/zspeed heady duty fork and shift plate everything else replaced except slave and master cylinder both of which were working 100% fine before install.
i have bled the clutch about 3 diff times now, its a 1pc line so only one bleed point, i adjusted both the rod and the switches...the rod was adjusted clockwise and out of room for further adjustment the switches are adjusted accordingly where the pedal just pushes against the switches. symptoms are i cant shift the car into 1st or reverse or any gear when the car is on, i can get it into second for some reason, there is a lot of chatter when the pedal is pushed to the floor...the pedal is not stiff till like halfway down, upon examining the slave cylinder i see the pin isnt pushing the fork enough, im out of adjustment on the pedal what else can it be? i have no leaks on either the slave or master anywhere i can see/feel
