TwinTurbo.NET: Nissan 300ZX forum - CAS injector test question...did I screw up?
Subject CAS injector test question...did I screw up?
Posted by Rcooke on May 28, 2013 at 8:34 PM
  This message has been viewed 293 times.
Message I am trying to isolate a cold start problem with my 91TT. During the process of cleaning all the connectors I decided to pull the CAS and see if the injectors were working. I rotated the CAS shaft counter clockwise and it seemed to cycle thru all the injectors with no problem. After a couple of cycles I think I accidently rotated the shaft clockwise. Now when I turn the CAS shaft counter clockwise it keeps firing the same injector (#6 cylinder). It's like it's stuck on that on injector. Did I screw something up by rotating the CAS shaft incorrectly or should it matter? Any suggestions? Thanks.
