TwinTurbo.NET: Nissan 300ZX forum - Do a boost leak test, unless you are getting kicked into
Subject Do a boost leak test, unless you are getting kicked into
Posted by ttsmokin on May 27, 2013 at 11:39 PM
  This message has been viewed 136 times.
In Reply To Turbo issue posted by TZAM on May 26, 2013 at 08:32 PM
Message safety boost, the ecu will not limit your boost. If you are going into safety boost the ecu believes your engine is knocking. Or you have a code 34 that pops up occasionally. Check ECU codes as well.
Might as well do the 6P's for maximum performance.
http://www.twinturbo.net/nissan/300zx/forums/technical/view/922678/The-6-Ps-Proper-Preparation-Prevents-Piss-Poor-Performancegt.html
