TwinTurbo.NET: Nissan 300ZX forum - Starter issues '92 NA
Subject Starter issues '92 NA
Posted by vorpalZ on May 27, 2013 at 9:29 AM
  This message has been viewed 249 times.
Message Hey all,
Helping a neighbor kid with his '92 NA, having a starter issue:
Replaced #3 injector with the dremel method... went to start the car and the starter cranks and then catches and quits. Subsequent attempts will only result in a single crank and quit, and sometimes not even that. If you leave it, it will crank one or twice and stop again. The other symptom is that every time you key the starter on, the battery resets the cabin electronics, stereo & clock revert.
Things I have done:
- Metered the battery, 12.2V at rest. Cleaned & tightened lugs. inspected pos & neg cables... look fine.
- Replaced the starter
- checked 12V lug at starter, 12.2 V
- turned the crank bolt and inspected the flywheel ring gear, engine turns and clutch & flywheel are fine.
- added grounding as per this post: grounding
-pulled and bypassed the starter relay, no difference
- inspected 12V power cable from battery to starter, seems fine. continuity checks OK
-jumped the battery with my Frontier, same issue
What I have not done:
- replaced starter relay in fender well
- traced the single wire off the starter forward
Thoughts?
Thanks,
MY Zs ARE HYBRID VEHICLES, THEY RUN ON
GASOLINE AND MONEY
"I expressed no attitude, I'm correcting you. If you don't
like it, try not to be wrong next time. Now you're getting
attitude, and if you don't like that you should grow a thicker
skin.”
- TriniTT 14:04:16 12/22/12
”Exhaust doesn't produce horsepower”
- VERTTZ 13:17:22 06/26/12
I'm off to wax mine and go for a drive now.
- BigTDogg (MA) 07:17:08 07/17/09
times
change, people change, but the Z32 still kicks ass.
- apudapus 16:46:02 06/15/07
I was more
wondering how you set your climate control to 22* lol, it
would be that fastest freezer on wheels!
- Briscoe'sZ32 (NJ) 23:15:44
02/05/07
You have *got* to be getting a cut from
B&B :D
- SeedyROM 15:24:29 08/16/06
What do you think B&B stands for?
- YugoBernie (NoVA) 15:57:09
08/16/06
