TwinTurbo.NET: Nissan 300ZX forum - Re: Timing Belt rubbing and smoking
wild_maxx
on May 26, 2013 at 3:37 PM
posted by baggar11
on May 26, 2013 at 03:18 PM
Did you install the rear crank washer plate? That would be my first guess.
baggar11
15:18:30 05/26/13
Re: Timing Belt rubbing and smoking -
wild_maxx
15:37:43 05/26/13
Yeah, both front and rear crank washers are installed.
baggar11
15:44:24 05/26/13
You have a bent/Loose Idler Stud..
Cjw3
16:32:16 05/26/13
With a good idler stud...
baggar11
16:42:22 05/26/13
My 2 NA Belts wander a little, but like the front (n/m)
Cjw3
16:58:00 05/26/13
If everything checks out, do we want to install the belt
baggar11
17:04:50 05/26/13
The belt will center itself.. Something is Bent/Crooked. (n/m)
Cjw3
17:36:47 05/26/13
Update, here's where it's rubbing...
baggar11
16:23:06 05/26/13
Re: Update, here's where it's rubbing...
wild_maxx
16:29:20 05/26/13
Yeah, everything was flush.
baggar11
16:40:56 05/26/13
Make sure you don't have and idler pulley bent. (n/m)
ChaseGrayTT
17:47:03 05/26/13
Recently there have been some auto tensioners that
Evan_Wright (Ca)
17:52:37 05/26/13
Update: Found the problem
baggar11
18:18:39 05/26/13
Congrats!
OverZealous (CT)
23:21:00 05/26/13
