TwinTurbo.NET: Nissan 300ZX forum - typical places for leaks are the o-rings at the compressor
Subject typical places for leaks are the o-rings at the compressor
Posted by aliaZ on May 26, 2013 at 3:35 PM
  This message has been viewed 246 times.
In Reply To Tips for finding a/c leak(s) without engine in car? posted by bartz32tt on May 26, 2013 at 12:45 PM
Message connections and the o-rings on the expansion valve inside the evaporator box.
For the sake of finding the leak, it is possible to partially charge the system without an engine. Immersing the R-134a can in a pan of hot water will cause the refrigerant to boil off and force it into your system.
You can then detect leaking o-rings with a soapy water solution.
While the engine is out is the best time to do a correct retrofit. Flush all of the lines, replace o-rings, remove the evaporator box and flush out the evaporator, etc
