TwinTurbo.NET: Nissan 300ZX forum - Sounds like your pedal adjustment is off.
Subject Sounds like your pedal adjustment is off.
Posted by TriniTT on May 25, 2013 at 1:17 PM
  This message has been viewed 177 times.
In Reply To Clutch engaging too early, getting stuck in gear, help!? posted by Mikester(Seattle) on May 25, 2013 at 04:10 AM
Message You need to get under there and make sure your master cylinder piston rod is able to fully retract. There are 2 switches that are depressed with the pedal at full rest. Remove the connectors and back those switches out by loosening the nut and unscrewing them. Adjust the rod on the pedal by loosening the nut on the rod at the pedal then turning the rod with a pair of pliers until there is no pressure on the rod with the pedal at rest. Then, screw the switches back in so they are depressed at pedal rest, but not putting pressure on the pedal.
If the master rod is not allowed to fully retract, the fluid will get hot and have no way to flow back into the master cylinder, causing a very similar issue to what you're having by creating a constant pressure in the hydraulic system.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
