TwinTurbo.NET: Nissan 300ZX forum - The hole is OEM and allows for oil to be released>>>
Subject The hole is OEM and allows for oil to be released>>>
Posted by ZUL8TR on May 24, 2013 at 7:37 AM
  This message has been viewed 134 times.
In Reply To Re: Could be a leaking rear main seal posted by brane123 on May 21, 2013 at 06:46 PM
Message rather than accumulate in the bell housing and affect the clutch. However oil leaking out the hole is not normal, a seal is leaking. Have you determined if it is transmission gear lube or engine oil? Smell it, gear oil has a sulfer smell. I assume you have a manual tranny. If auto tranny look for a red color fluid if not too contaminated otherwise a brownish red. If engine oil compare to dip stick sample to determine that oil in leak.
ZUL8TR in Orlando,FL
