| Message |
Preventative maintenance id key to keeping these old girls running right... first off check every connection you can find for corrosion, good contact and clips (be careful not to break any). check CAS, MAF, PTU, TPS, injectors & coil packs... check and replace air & fuel filters & spark plugs. and read this.. La-Z-Link also run diagnostics on the ECU and if still no clue maybe get conzult, ecutalk or other software to investigate... Or take it to a 300zx competent garage (few and far between)
