TwinTurbo.NET: Nissan 300ZX forum - Speed sensor wireing/path
Subject Speed sensor wireing/path
Posted by mikuZ on May 23, 2013 at 5:37 PM
  This message has been viewed 402 times.
Message Does anyone know how speed sensor signal is leaving gauge cluster? My power steering is not working, happens under acceleration. HICAS light comes on, I used HICAS diagnostic and it's giving me speed sensor, also when I connected Conzult it's showing no speed signal. However my speedometer is working and odometer is working. tested them against GPS, all turned out fine. Also I resoldered all connections on speedometer cluster, that didn't help. So as far as I know, signal goes like this: speed sensor -> gauge cluster -> ECU -> HICAS/PS. I'm guessing wire between cluster and ECU is the problem, but I have no idea what wire it's using to leave cluster.
