TwinTurbo.NET: Nissan 300ZX forum - I'm no tuning expert by any means
300ZMang
on May 23, 2013 at 1:19 PM
Timing at WOT...
posted by puchy
on May 23, 2013 at 12:06 PM
But I'm preeeeetty sure your timing should be 15.
Your timing will be different, and bouncy however, at idle.
Search for CAS issues
Timing at WOT...
puchy
12:06:52 05/23/13
I'm no tuning expert by any means -
300ZMang
13:19:08 05/23/13
Yeah, the base is 15 but depending on load it will change...
puchy
13:40:27 05/23/13
Timing should not be bouncy at idle, it should be smooth.
TriniTT
10:58:55 05/24/13
Thanks
300ZMang
11:11:55 05/24/13
Just trying to clear the confusion.
TriniTT
11:49:12 05/24/13
Ah yes, so "cold" timing at idle is what my brain was
300ZMang
11:53:25 05/24/13
Yes, I could call SZ and I bet Greg or Seb will give....
puchy
20:11:12 05/24/13
thats the nature of timing to decrease at high rpm and load
Dane (Houston)
13:27:52 05/23/13
Re: thats the nature of timing to decrease at high rpm and load
puchy
14:04:39 05/23/13
Looking at these graphs, you may be correct...
puchy
14:12:30 05/23/13
I'd say do the test via the ECU
300ZMang
14:39:39 05/23/13
Yeah. Pretty obvious. Talk to ZromTech.
OverZealous (CT)
15:10:40 05/23/13
I will be reseting the ECU as soon as I get home and recheck (n/m)
puchy
15:54:46 05/23/13
checking the timing map with my conzult, I notice that...
puchy
08:11:38 05/24/13
That's not OEM. Might be normal for SZ chip.
OverZealous (CT)
18:54:27 05/25/13
