TwinTurbo.NET: Nissan 300ZX forum - Yes, completely delete the PCV valve lineset.
Subject Yes, completely delete the PCV valve lineset.
Posted by ZinnZ32 on May 22, 2013 at 1:50 PM
  This message has been viewed 1076 times.
In Reply To Well done posted by RobZ32 on May 22, 2013 at 11:04 AM
Message Cap off/plug DS rear valve cover ports, Accordion pipes (Normally run to front Valve cover breather tubes). And then Plug the PCV inlets into the plenum. 1/4" npt Plugs can fit where the PCV valves go, just don't thread them too hard, and use a pipe sealing compound. Or even better, use a tap and get the plenum cleaned after - I did that when I was doing other work on it.
__________
Version 3.01
