TwinTurbo.NET: Nissan 300ZX forum - While I understand your logic
Red Hawk (CO)
on May 22, 2013 at 10:56 AM
I used to have VTA with the terminations in the trans tunnel
posted by ZinnZ32
on May 22, 2013 at 10:22 AM
Its impossible to get enough pressure in a VTA system to cause damage. if I boost leak test my car I have to plug them because of the amount of air loss.
TT BEAST IN PROGRESS!
VG Exhaust Crankcase Evacuation Setup! My Z Experiment...
ZinnZ32
22:13:57 05/21/13
Idiot...
MeatMan - 604Z.ca -
22:28:04 05/21/13
Like the idea but...
alpha_omega16
22:41:10 05/21/13
@ Alpha, in this case. I have a MAP sensor! Avec AEM EMS S2 (n/m)
ZinnZ32
23:04:37 05/21/13
The way I see it >>>
Xteam300TT (South Tx )
11:50:38 05/22/13
google "krankvent" (n/m)
The Devils Z
14:49:20 05/22/13
*Stands and claps*
Jim (Selin Design)
22:46:34 05/21/13
Jim, I've only heard at higher RPM the Vacuum plateaus...
ZinnZ32
23:08:25 05/21/13
I can't imagine significant power gains but I like it
OverZealous (CT)
15:39:45 05/23/13
Good work! (n/m)
ttsmokin
23:06:25 05/21/13
Re: VG Exhaust Crankcase Evacuation Setup! My Z Experiment...
Tech@EPR
23:10:41 05/21/13
Zerosum
23:13:19 05/21/13
I did this back in 2005...
Crazy Greek
01:30:52 05/22/13
I followed Ash's write-up, which taps into the valve covers
ForceFedTT (SoCal)
02:27:30 05/22/13
Ash's most recent post indicated to VTA only, no filter
TriniTT
08:42:44 05/22/13
ZinnZ32
10:22:50 05/22/13
While I understand your logic -
Red Hawk (CO)
10:56:19 05/22/13
soulpwr
01:47:13 05/22/13
Yes you can run mech/elec vacuum pumps, cobra pump, etc...
ZinnZ32
10:26:44 05/22/13
Beautiful Z. I should go see this in person one day. (n/m)
Jiro
01:49:37 05/22/13
Hey, dumbass..get flexjoints if ur gonna be pogosticking
ForceFedTT (SoCal)
02:21:13 05/22/13
well done
aliaZ
06:10:24 05/22/13
Nicely done. Where do you connect on the engine? (n/m)
08:51:33 05/22/13
"Ran 5/8" Hose from my front breather tubes" (n/m)
MixManMash
10:10:09 05/22/13
So the ones on the intake valve covers? (n/m)
10:21:13 05/22/13
Yes, the front tubes. And plug the rest/PCV valve ports. (n/m)
ZinnZ32
10:37:42 05/22/13
That's where I was confused, because you said you plugged
10:43:45 05/22/13
Yeah lol. Ah, the PVC hose... Yeah, it can melt.
ZinnZ32
13:42:37 05/22/13
Very cool mod!
Bigwill837
10:39:41 05/22/13
I agree you could use a catch can but it doesn't effect much
ZinnZ32
13:52:26 05/22/13
Well done
RobZ32
11:04:09 05/22/13
Yes, completely delete the PCV valve lineset.
ZinnZ32
13:50:19 05/22/13
very clever (n/m)
13:06:08 05/22/13
You should post this in Technical so it can be VTFed. (n/m)
MixManMash
15:42:06 05/22/13
I considered it, I guess I will...
ZinnZ32
17:57:09 05/22/13
I'm thinking a better designed venturi could give you
Jim (Selin Design)
17:15:33 05/22/13
I agree...
ZinnZ32
17:58:39 05/22/13
WazTTed
18:03:09 05/22/13
Wire for the starter solenoid... Lol - And...
ZinnZ32
21:20:06 05/22/13
