TwinTurbo.NET: Nissan 300ZX forum - Re: The fuel pump controller chassis must be grounded.
Subject Re: The fuel pump controller chassis must be grounded.
Posted by ariz on May 17, 2013 at 1:52 PM
  This message has been viewed 249 times.
In Reply To The fuel pump controller chassis must be grounded. posted by DVDBURN (MD) on May 17, 2013 at 01:21 PM
Message no luck... will install like you say, making sure they ground. i just wanted to rule out the control being bad by momentarily swapping a tt one. If this does not work I am at a dead end. nothing has been messed with. I got continuity in all the wires (chased them all from beginning to end thinking i had a break somewhere,... nothing. the system worked fine until l i installed a new wiring specialties EFI harness. I am starting to think something is no right with it because i have replaced the fuses, the link, the relay and the controller... any suggestions?? can a bad portion of the EFI harness be causing my problem? HELP ON THIS ONE!!!!
