TwinTurbo.NET: Nissan 300ZX forum - There is absolutely NO WAY the r134a condenser
Subject There is absolutely NO WAY the r134a condenser
Posted by JMartz on May 17, 2013 at 7:36 AM
  This message has been viewed 379 times.
In Reply To AC cooling issue (long) posted by SkiFly01 on May 16, 2013 at 05:02 PM
Message will hurt cooling. Look for a problem elsewhere. Look at the evap temp control systems. Expansion valve and TSV, as well as the evap itself. I assume refrigerant level is correct and pumping pressures within spec. If your car has auto air (stupid system), there is an ambient temp sensor that prevents the compressor from engaing below some temp near freeezing. Look at the temp/voltage responseof that (not sure if r12 cars have that though). Remember there is no cabin filter. Every so and then the air box has to be split and the evap cleaned. The electromagnetic clutch coil somtimes engages but does not hold.
