TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel problem now is problem.
speedy z
on May 16, 2013 at 9:05 PM
posted by speedy z
on May 15, 2013 at 09:37 PM
could it be that both my turbos are fried? I still get like 2-3 psi?
speedy z
21:37:09 05/15/13
should be steady 36psi at idle (n/m)
BarryGZX
22:20:22 05/15/13
I read that if fuel pressure vibrates it is dampner
speedy z
22:28:02 05/15/13
Re: I read that if fuel pressure vibrates it is dampner
Full_Metal_Jacket
14:18:29 05/16/13
Re: Re: I read that if fuel pressure vibrates it is dampner
speedy z
20:32:30 05/16/13
Full_Metal_Jacket
17:01:12 05/18/13
Have you checked pressure by turning the key fwd to the on
jmt-z
15:54:09 05/16/13
Yes fuel pressure is fine. Just no stinking boost. (n/m)
speedy z
20:58:32 05/16/13
Re: Fuel problem now is problem. -
speedy z
21:05:35 05/16/13
could it be that both my turbos are fried? I still get boost (n/m)
speedy z
21:06:14 05/16/13
your ecu isnt throwing any codes??? (n/m)
BarryGZX
22:16:16 05/16/13
No codes on the ECU. car runs fine just no boost
speedy z
08:47:54 05/17/13
did u check wastegate solenoids...operation (n/m)
BarryGZX
09:01:00 05/17/13
How do i check that. i assume getting it in the air
speedy z
11:35:24 05/17/13
u know some codes dont throw check engine light? Like
BarryGZX
12:06:23 05/17/13
i checked it from the ECU. 5 long 5 short (n/m)
speedy z
12:43:34 05/17/13
when u disconnect fuel regulator...pressure should rise
BarryGZX
12:58:22 05/17/13
NOT SURE IF THIS IS GOOD OR BAD> NO more issues
speedy z
21:10:30 05/17/13
Could you feel the difference? Maybe a bad boost gauge. (n/m)
Full_Metal_Jacket
14:10:44 05/18/13
Oh yeah night and day. definatly not a gauge issue
speedy z
21:05:06 05/18/13
