TwinTurbo.NET: Nissan 300ZX forum - Disconnect the wires going to them and drive around
Summeronthechain (MN)
on May 16, 2013 at 9:40 AM
Re: Maybe you replaced the regulator with a dampner
posted by speedy z
on May 15, 2013 at 05:01 PM
See if there are any changes in boost level. Be careful not to overboost if it lets you, though.
Need help with possible safety boost. followed all tech
speedy z
22:27:50 05/14/13
hmm.. safety boost usually tops out at 7 psi (n/m)
BarryGZX
01:43:07 05/15/13
do cylinder drop test
Dane (Houston)
02:16:28 05/15/13
Re: do cylinder drop test
speedy z
09:07:41 05/15/13
ecu has no control over how much safety boost just on or off
Dane (Houston)
13:56:28 05/15/13
would low fuel pressure limit the boost like this ??
speedy z
16:11:16 05/15/13
Possibly, but it would cause all sorts of other issues
09:38:53 05/16/13
I found that, in my experience with my 92' boost solenoids,
ZTicket(Dallas)
08:36:54 05/15/13
Very well could be your stock boost solenoids.
DVDBURN (MD)
15:58:22 05/15/13
Krazyd27(Houston)
16:51:54 05/15/13
speedy z
17:01:55 05/15/13
Disconnect the wires going to them and drive around -
09:40:14 05/16/13
~32 psi fuel pressure after ther fuel filter.
speedy z
18:56:52 05/15/13
