TwinTurbo.NET: Nissan 300ZX forum - Also cleaned best I could the fwd plug on the TPS. Looked a
Subject Also cleaned best I could the fwd plug on the TPS. Looked a
Posted by jmt-z on May 15, 2013 at 5:08 PM
In Reply To Checked the TPS and it looked good, set at .44 and hard idle posted by jmt-z on May 15, 2013 at 05:05 PM
Message bit gummed up. Probably look to replace it but for now I think it may be ok. I'll have to get to the ecu to run a continuity check between the two I guess
"If everything seems under control, you're just not going
fast enough."
- Mario Andretti
