TwinTurbo.NET: Nissan 300ZX forum - ecu has no control over how much safety boost just on or off
Subject ecu has no control over how much safety boost just on or off
Posted by Dane (Houston) on May 15, 2013 at 1:56 PM
  This message has been viewed 156 times.
In Reply To Re: do cylinder drop test posted by speedy z on May 15, 2013 at 09:07 AM
Message one ecu to another can not change the amount of safety boost, only wastegate tension preload can change the amount of safety boost.
limited boost can be caused by so many things:
leaks
timing belt
bad maf
low fuel pressure
clogged cats
dead injectors
ptu issues
tps
turbos
and much more
3psi is not or more than a safety boost system failure
Houston Z
www.houston-nissans.com
