TwinTurbo.NET: Nissan 300ZX forum - Vacuum is normal in the crank.
Summeronthechain (MN)
on May 15, 2013 at 10:36 AM
pass side turbos burn oil
posted by TJSB
on May 14, 2013 at 06:49 PM
The PCV valves are open when the car is in vacuum and constantly sucking fumes out of the crank, therefore its under vacuum.
TJSB
18:49:12 05/14/13
When does it smoke? At idle, under acceleration, cold, warm?
white22sky
08:50:25 05/15/13
Re: When does it smoke? At idle, under acceleration, cold, warm?
TJSB
11:20:25 05/15/13
You say after idle, you mean at idle? (n/m)
white22sky
12:26:59 05/15/13
Re: You say after idle, you mean at idle?
TJSB
15:47:48 05/15/13
Vacuum is normal in the crank. -
10:36:27 05/15/13
