TwinTurbo.NET: Nissan 300ZX forum - Injectors are fairly new nismo 740's. I pressure tested them
Subject Injectors are fairly new nismo 740's. I pressure tested them
Posted by Evan_Wright (Ca) on May 10, 2013 at 3:38 PM
  This message has been viewed 277 times.
In Reply To I would def try swapping out an ECU posted by Summeronthechain (MN) on May 10, 2013 at 03:17 PM
Message to 70psi under water when I first installed them. Took the rails out again a few weeks ago thinking the same thing as you and pressurized them again to 70psi under water. No leaks. I also did a little test to rule out sticky injector:
[ http://twinturbo.net/nissan/300zx/forums/general/view/2539743/DIY-injector-flow-testingtoo-imprecise-to-be-conclusive.html ]
Wish I could swap ecu's but still trying to determine most economical option. I'm afraid to buy used and just end up with someone else's problem ecu. Can't find brand new anymore, only remanufactured's ecu's. and the problem with that is ill need to open it up and have a socket installed which means ill void any warranty on the reman. Decisions, decisions...
