TwinTurbo.NET: Nissan 300ZX forum - Re: Throttle Linkage is Sticking
quadratique
on May 10, 2013 at 9:41 AM
posted by f1ym4n
on May 10, 2013 at 06:47 AM
I had similar problem and after some research I noticed that the part circled in yellow was touching the arm of the spring throttle. I just pushed it back and the problem was solved.
f1ym4n
06:47:53 05/10/13
Check for obstructions and clean out your TB's.
white22sky
08:46:31 05/10/13
Re: Throttle Linkage is Sticking -
quadratique
09:41:04 05/10/13
Agreed... same thing happened to me but other side..
Medallion Man
13:45:00 05/10/13
Pedal is loose up until the point where the cable goes
f1ym4n
16:50:42 05/10/13
Its just the PCV breather. Its pressed in. (n/m)
Summeronthechain (MN)
14:15:57 05/10/13
