TwinTurbo.NET: Nissan 300ZX forum - not sure what to suggest then
aliaZ
on May 09, 2013 at 8:30 PM
The clutch pedal does not feel hard when it is slipping.
posted by SpeedyZX
on May 09, 2013 at 06:20 PM
clutch engagement point stays the same?
I've been having issues with my Exedy twin carbon multi
SpeedyZX
12:57:14 05/09/13
I think you have air in your lines (n/m)
aliaZ
14:04:51 05/09/13
But it feels like the clutch plate is slipping on the
SpeedyZX
14:16:52 05/09/13
yes, air in the lines could cause that
aliaZ
15:23:10 05/09/13
SpeedyZX
18:20:22 05/09/13
not sure what to suggest then -
aliaZ
20:30:33 05/09/13
I have your answer.
TriniTT
22:13:15 05/10/13
Thanks J, I'll have my mechanic look into that scenario.
SpeedyZX
23:28:56 05/10/13
although it has been 8 years since I deleted my upper bleed
aliaZ
08:01:07 05/12/13
^Yep, this too and here is a link to help fix this issue:
TriniTT
12:42:10 05/12/13
no, I was talking about the pushrod that comes out of the
aliaZ
11:50:04 05/13/13
But if you adjust the slave pin, you don't have to adjust
TriniTT
00:42:52 05/14/13
correct
aliaZ
06:25:57 05/15/13
The question to pose now: is the best method for adjustment
TriniTT
13:46:59 05/15/13
Longer slave pin is not correct......
Greg D. (Specialty-Z)
14:45:31 05/15/13
Then can you explain why every time I've adjusted per your
TriniTT
15:30:22 05/15/13
Very simple, your not adjusting it correctly
22:05:42 05/15/13
I'm such an ass.
TriniTT
00:29:51 05/20/13
*once the master rod was all the way out, not slave. (n/m)
TriniTT
16:18:06 05/21/13
