TwinTurbo.NET: Nissan 300ZX forum - Re: Front Tie Rod Lock Nuts
Subject Re: Front Tie Rod Lock Nuts
Posted by charleyd on May 09, 2013 at 7:16 PM
  This message has been viewed 165 times.
In Reply To Front Tie Rod Lock Nuts posted by ZXRider on May 09, 2013 at 12:37 AM
Message Put one wrench on the locknut, and another on the tie rod end (There are flats close to the nut for a wrench.). Then wedge another wrench or the handle of your socket wrench between the two wrenches and force them to rotate relative to each other. You can get a great mechanical advantage this way. Use a longer wrench like a breaker bar or a length of pipe if you need more leverage.
