TwinTurbo.NET: Nissan 300ZX forum - It is my understanding a bleeder is not necessary.
Subject It is my understanding a bleeder is not necessary.
Posted by TriniTT on May 08, 2013 at 10:02 AM
  This message has been viewed 239 times.
In Reply To Install brake bleeder on '95 ABS unit to remove air? posted by mskdallas on May 07, 2013 at 11:40 PM
Message The reason most recommend ATE Blue (or switch back to yellow) is so that you can see once you've pulled the fluid all the way through the line when it changes colors. It must go through the ABS unit before it reaches the caliper, so you know there isn't much potential for air to stay in the lines when you complete the proper bleed procedure and see the fluid color change.
If you do have air in the lines and you believe you bled the system well, I would follow each line and connection to ensure you have no minor leaks anywhere.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
