TwinTurbo.NET: Nissan 300ZX forum - Install brake bleeder on '95 ABS unit to remove air?
Subject Install brake bleeder on '95 ABS unit to remove air?
Posted by mskdallas on May 07, 2013 at 11:40 PM
  This message has been viewed 267 times.
Message I have a '95 car that is basically a track car with AP brakes on all four corners. At recent NASA event at TWS I lost brakes on the back stretch. Almost had a huge off. I have SS lines, recently bleed the whole system with Motul 660. TWS is not a heavy braking track (just high speed). I think I have air in the ABS unit and wanted to know if anyone has installed a bleeder on a 95+ car to remove air from the ABS unit. Or has found a way to remove air from the unit since there are no bleeders. Also, how critical is it the negative battery cable is disconnected? Is this for the ABS unit or to save battery life? Thanks
