TwinTurbo.NET: Nissan 300ZX forum - SZ 300 Degree Fuel Line Kit Question..........
Subject SZ 300 Degree Fuel Line Kit Question..........
Posted by ZaXxon on May 04, 2013 at 12:55 PM
  This message has been viewed 271 times.
Message Lines are installed and I am pressure testing. The 45 degree fitting on the front crossover line is leaking at the swivel (not the threads). Also, the RH rear line fitting is leaking at the same spot, again....the swivel not the threads.
I have disassembled and re-assembled a number of times with exactly the same results. I used a small amount of oil on the threads, per some online advice and the threads are sealing great.
Any tips on getting the swivels to seal? Do I have bad fittings?
