TwinTurbo.NET: Nissan 300ZX forum - remove old fluid from reservoir before adding new
DaZedMan
on May 03, 2013 at 3:19 PM
Tips on flushing/changing brake fluid with ABS?
posted by Jayru
on May 03, 2013 at 11:56 AM
I use a turkey baster (plastic tube with rubber bulb) to remove all the old fluid from either the brake or clutch master cyl reservoirs before changing fluid type or flushing system. Amazing how much crud builds up in the reservoirs from normal use.
Jayru
11:56:11 05/03/13
<-- Tech
spicyZ
12:21:52 05/03/13
There is a bleed procedure in the FSM
BlackholeZ
12:35:51 05/03/13
remove old fluid from reservoir before adding new -
DaZedMan
15:19:17 05/03/13
