TwinTurbo.NET: Nissan 300ZX forum - There is a bleed procedure in the FSM
Subject There is a bleed procedure in the FSM
Posted by BlackholeZ on May 03, 2013 at 12:35 PM
  This message has been viewed 665 times.
In Reply To Tips on flushing/changing brake fluid with ABS? posted by Jayru on May 03, 2013 at 11:56 AM
Message I used a bleeder bottle like this. You put a little fluid in the bottle to begin with, and attach the tube to the bleeder on the caliper. There is a straw inside that stays submerged in the brake fluid, so the caliper doesn't suck air back in. Then you just pump the pedal till you get fresh fluid. Switching between colored fluids like ATE Blue and Gold makes it easy to tell when you have new fluid. Don't forget to keep the reservoir full. ;-)
-Dan
VTC Solenoid Caps and install instructions.
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
" Purrs like a sexually satisfied black panther." - BigTDogg
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
