TwinTurbo.NET: Nissan 300ZX forum - use variable speed 3/8" or 1/2" drill and >>
Subject use variable speed 3/8" or 1/2" drill and >>
Posted by ZUL8TR on May 03, 2013 at 5:59 AM
  This message has been viewed 511 times.
In Reply To Appreciate the help guys! posted by dvice on May 02, 2013 at 05:34 PM
Message set rpm and stroke to get a cross hatch pattern with 40 to 45 degree angle between up spiral and down spiral lines like this.
[ http://www.google.com/imgres?q=cylinder+cross+hatching+tool&um=1&sa=N&hl=en&tbm=isch&tbnid=9fLV25GA_NBMeM:&imgrefurl=http://www.hastingsmfg.com/ServiceTips/cylinder_bore_refinishing.htm&docid=VMP8QRLtvOkHhM&imgurl=http://www.hastingsmfg.com/ServiceTips/images/p76.gif&w=450&h=194&ei=x5WDUe-NJoSg8QTViIHoAQ&zoom=1&biw=1440&bih=673&iact=rc&dur=235&page=1&tbnh=117&tbnw=256&start=0&ndsp=30&ved=1t:429,r:26,s:0,i:167&tx=126&ty=50 ]
Place the hone in the bore and remove from the bore with drill turning. Usually about 400 rpm and stroke up and down 1 sec in 1 sec out. Use lots of the correct lube lube. Do not clean with solvents, use soapy hot water and scrub with a toilet bowl cleaner type brush. Then wipe with a lint free cloth till there are no deposits. Then wipe on motor oil to keep rust from forming. Keep everything super clean.
ZUL8TR in Orlando,FL
