TwinTurbo.NET: Nissan 300ZX forum - One last thing to keep in mind, transmissions are
Subject One last thing to keep in mind, transmissions are
Posted by JMartz on May 02, 2013 at 1:29 PM
  This message has been viewed 169 times.
In Reply To There is a bearing on the front of the trans, posted by JMartz on May 02, 2013 at 01:19 PM
Message NOT REBUILDABLE. Except for the case bearings and synchros, everything else rolls on itself. there are no "races" to replace. A bad gear needle bearing surface, if scored, will require the replacement of the gear itself as well as the shaft it rolls on. Pretty quickly you can see the futility of "rebuilding".
