TwinTurbo.NET: Nissan 300ZX forum - A note of caution: sometimes it is not obvious
Subject A note of caution: sometimes it is not obvious
Posted by JMartz on May 02, 2013 at 1:24 PM
  This message has been viewed 181 times.
In Reply To There is a bearing on the front of the trans, posted by JMartz on May 02, 2013 at 01:19 PM
Message when you look at a bearing if it is bad and a noise maker. Drain the oil in the transmission and look for metal particles on the magnetic plug. If you find a large amount, that may indicated a problem. Transmissions do shed metal so unless there is a lot don't get too concerned.
