TwinTurbo.NET: Nissan 300ZX forum - Doing the job quickly requires utilizing the proper tools.
Subject Doing the job quickly requires utilizing the proper tools.
Posted by TriniTT on May 02, 2013 at 10:13 AM
  This message has been viewed 300 times.
In Reply To I would not consider it "incredibly easy". (n/m) posted by MrPulldown(Tahoe) on May 01, 2013 at 05:14 PM
Message These include:
transmission jack
several ratchet extensions - all the upper bellhousing bolts can be removed with a very long ratchet extension coming from the tail of the bellhousing. I see a lot of people trying to use a stubby wrench on the bellhousing bolts and that is futile.
You must:
Disconnect battery. Remove 6 bolts for exhaust, pop hangers off, exhaust out in under 10 mins.
Disconnect the trans wire harness 3 connectors, move out of the way. Remove the 2 slave cylinder bolts, hang it out of the way. Remove the starter, move it out of the way. 5 mins.
Remove the 4-6 bolts on the driveshaft (and 2 carrier bearing bolts if oem 2-piece) and slide it out. Then remove the shifter linkage bolt. Again, you're looking at 5 minutes.
Remove the 9ish transmission bellhousing bolts. This takes me maybe 10-15 minutes.
Remove the 4 trans crossmember bolts. 1 minute?
The trans slides right out. I can't fathom an easier transmission removal process.
This is for the owner/wrencher using jackstands.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
