TwinTurbo.NET: Nissan 300ZX forum - 2nd that...
2nd that...
CameronSF
on May 01, 2013 at 2:30 PM
Maybe you developed a major vacuum leak in your clutch
posted by BoneZ (MD)
on May 01, 2013 at 02:18 PM
I did the same when I blew out the slave cylinder on my old NA. Not fun but I was close to home and saved a tow. Did you say you have no pedal pressure? You may have busted off your pivot ball as well...
Need quick help
300ZMang
13:22:55 05/01/13
Re: Need quick help
300ZMang
14:17:00 05/01/13
BoneZ (MD)
14:18:57 05/01/13
BoneZ (MD)
14:20:16 05/01/13
any way to do this with the clutch pedal start switch still
fuzzymonkey
15:25:19 05/01/13
as long as the switch is working properly, yes
BoneZ (MD)
17:00:34 05/01/13
2nd that... -
CameronSF
14:30:28 05/01/13
car will start but wont go into gear, pedal is very little
300ZMang
14:46:51 05/01/13
Can you get it into gear with car off? (n/m)
CameronSF
14:57:53 05/01/13
yes goes into gear
300ZMang
15:52:26 05/01/13
I gotta go with Bernie and Tim on this..
CameronSF
16:12:21 05/01/13
i have the chromoly pivot ball already
300ZMang
16:29:32 05/01/13
it stopped working out of nowhere.
300ZMang
14:48:07 05/01/13
I'm thinking maybe your pivot ball broke.
TriniTT
15:03:22 05/01/13
or even a loose spring from the friction disc. (n/m)
15:18:34 05/01/13
2nd (n/m)
Woody75 (Denver)
15:58:11 05/01/13
can start car up in gear and clutch is engaged. wants
300ZMang
15:50:19 05/01/13
If its the disc you can get just new one of those.
Woody75 (Denver)
16:00:43 05/01/13
The easiest way around "what ifs" is to just look at it.
TriniTT
16:02:59 05/01/13
I would not consider it "incredibly easy". (n/m)
MrPulldown(Tahoe)
17:14:12 05/01/13
pretty close to.
fuzzymonkey
17:34:02 05/01/13
nor anywhere near that fast for a owner/wrencher. Kind of
jzack
18:05:15 05/01/13
Doing the job quickly requires utilizing the proper tools.
TriniTT
10:13:25 05/02/13
I would barely agree, *if he had air tools
Zvil (FL)
23:58:25 05/03/13
I just laid out steps with relative times.
TriniTT
07:33:15 05/04/13
Not saying you cant but I think 30minutes is very optimistic
Zvil (FL)
12:42:48 05/04/13
Not including jack time, I loathe raising a car
TriniTT
13:51:04 05/04/13
