TwinTurbo.NET: Nissan 300ZX forum - Need quick help
Need quick help
300ZMang
on May 01, 2013 at 1:22 PM
While driving clutch lost all pressure. master still has all fluid in it and no signs of leaks anywhere. is it my slave? it will start and idle but dies when i push in the clutch. thanks guys im stranded now
Need quick help -
300ZMang
13:22:55 05/01/13
Re: Need quick help
300ZMang
14:17:00 05/01/13
Maybe you developed a major vacuum leak in your clutch
BoneZ (MD)
14:18:57 05/01/13
BoneZ (MD)
14:20:16 05/01/13
any way to do this with the clutch pedal start switch still
fuzzymonkey
15:25:19 05/01/13
as long as the switch is working properly, yes
BoneZ (MD)
17:00:34 05/01/13
2nd that...
CameronSF
14:30:28 05/01/13
car will start but wont go into gear, pedal is very little
300ZMang
14:46:51 05/01/13
Can you get it into gear with car off? (n/m)
CameronSF
14:57:53 05/01/13
yes goes into gear
300ZMang
15:52:26 05/01/13
I gotta go with Bernie and Tim on this..
CameronSF
16:12:21 05/01/13
i have the chromoly pivot ball already
300ZMang
16:29:32 05/01/13
it stopped working out of nowhere.
300ZMang
14:48:07 05/01/13
I'm thinking maybe your pivot ball broke.
TriniTT
15:03:22 05/01/13
or even a loose spring from the friction disc. (n/m)
15:18:34 05/01/13
2nd (n/m)
Woody75 (Denver)
15:58:11 05/01/13
can start car up in gear and clutch is engaged. wants
300ZMang
15:50:19 05/01/13
If its the disc you can get just new one of those.
Woody75 (Denver)
16:00:43 05/01/13
The easiest way around "what ifs" is to just look at it.
TriniTT
16:02:59 05/01/13
I would not consider it "incredibly easy". (n/m)
MrPulldown(Tahoe)
17:14:12 05/01/13
pretty close to.
fuzzymonkey
17:34:02 05/01/13
nor anywhere near that fast for a owner/wrencher. Kind of
jzack
18:05:15 05/01/13
Doing the job quickly requires utilizing the proper tools.
TriniTT
10:13:25 05/02/13
I would barely agree, *if he had air tools
Zvil (FL)
23:58:25 05/03/13
I just laid out steps with relative times.
TriniTT
07:33:15 05/04/13
Not saying you cant but I think 30minutes is very optimistic
Zvil (FL)
12:42:48 05/04/13
Not including jack time, I loathe raising a car
TriniTT
13:51:04 05/04/13
