TwinTurbo.NET: Nissan 300ZX forum - Re: Honing for OEM rings
Subject Re: Honing for OEM rings
Posted by Tech@EPR on May 01, 2013 at 6:13 PM
  This message has been viewed 513 times.
In Reply To Honing for OEM rings posted by dvice on May 01, 2013 at 05:06 PM
Message Here is what I'm referring to.
Many of us call it a dingle ball hone but the correct term is flex hone. I know this one states its for 89mm but that will work perfectly fine for what you need. The fact that the ball ends flex on the wire stems gives it the ability to adapt to the cylinder size. This particular unit is what I would purchase if I were you. Good luck
[ http://www.amazon.com/89mm-Flex-Hone-Cylinder-Silicon-Carbide/dp/B002PIG7FW/ref=sr_1_2?ie=UTF8&qid=1367449880&sr=8-2&keywords=89mm+flex+hone ]
Ep Racing | Create Your Badge
