TwinTurbo.NET: Nissan 300ZX forum - I dont recommend using that tool. You should try the tool
Krazyd27(Houston)
on May 01, 2013 at 5:58 PM
Honing for OEM rings
posted by dvice
on May 01, 2013 at 05:06 PM
With the little balls. This one will remove the cross hatch pattern in your cylinder walls. Ep racing or someone else will chime in shortly to clarify things
dvice
17:06:25 05/01/13
I dont recommend using that tool. You should try the tool -
Krazyd27(Houston)
17:58:36 05/01/13
Re: Honing for OEM rings
Tech@EPR
18:07:17 05/01/13
Tech@EPR
18:13:07 05/01/13
Appreciate the help guys!
dvice
17:34:45 05/02/13
Re: Appreciate the help guys!
Tech@EPR
18:53:08 05/02/13
Also it makes things easier removing the oil squirters
Krazyd27(Houston)
22:31:51 05/02/13
use variable speed 3/8" or 1/2" drill and >>
ZUL8TR
05:59:20 05/03/13
