TwinTurbo.NET: Nissan 300ZX forum - Get comparmentalized plastic containers
Subject Get comparmentalized plastic containers
Posted by megaDan on May 01, 2013 at 11:34 AM
  This message has been viewed 273 times.
In Reply To first engine pull posted by ZEchen951 on April 26, 2013 at 11:08 PM
Message I pick up a few when they go on sale. Helps organize bolts I have lying around the garage. I have a giant one I label with painters tape each time I do a big disassembly. I separate bolts into compartments, and then label where they came from. The painters tape allows me to easily remove the labels afterwards.
Also, label all your connections with painters tape if you can. Both vacuum hoses and electrical connections. You'll remember everything if you put it back together next week, but if you wait a year like I did you'll be scratching your head.
Also, if you are confused about anything taking it apart, as other people said...TAKE PICTURES so you can see how lines are routed and whatnot. Organiziation is absolutely key to making it a smooth process your first time.
