TwinTurbo.NET: Nissan 300ZX forum - Injector testing...sputtering issue
Subject Injector testing...sputtering issue
Posted by w8lifter21 on May 01, 2013 at 8:12 AM
  This message has been viewed 192 times.
Message I'm getting a sputter at low rpm, and intermittently feels like an injector cuts out completely. At idle/part throttle you can hear it, but then stepping into it more and into boost it seems to clear up and pull as it should. I had a similar problem on another z but the miss would come going over bumps and it turned the coilpack boots were the culprit.
For testing the ohms on these injectors, it can be done with them in the car I assume? The car does have 6 new OEM injectors about 5-6 years/10k ago so I wouldn't think they are going yet but it doesn't hurt to test.
