TwinTurbo.NET: Nissan 300ZX forum - I think I have it narrowed to the steering solenoid
Summeronthechain (MN)
on April 30, 2013 at 7:47 PM
No, the speed sensor is not bad
posted by DVDBURN (MD)
on April 30, 2013 at 04:25 PM
It ohms at 6.0, which is technically in the 4-6 ohm range specified. However, it failed the vibration test once voltage is applied and removed.
I will post my results back.
Can a speed sensor be bad and the Speedo still work?
10:23:24 04/29/13
Things I've checked:
10:30:50 04/29/13
You check the variable steering speed sensor on the rack?
baggar11
14:34:42 04/29/13
Is that different than the solenoid on the rack?
17:02:54 04/29/13
Might as well just remove all the HICAS stuff :-) (n/m)
Shiers69
21:35:33 04/29/13
check the wires going to the steering rack solenoid
aliaZ
00:09:24 04/30/13
DVDBURN (MD)
16:25:22 04/30/13
I think I have it narrowed to the steering solenoid -
19:47:48 04/30/13
