TwinTurbo.NET: Nissan 300ZX forum - I wouldn't consider that accurate either.
Subject I wouldn't consider that accurate either.
Posted by Tanley on April 29, 2013 at 8:28 PM
  This message has been viewed 412 times.
In Reply To Re: Do a leak down test. posted by hatchet502 on April 29, 2013 at 06:35 PM
Message A compression test is supposed to be done with the engine warm. For a compression test you are using the starter to turn over the engine at a certain RPM and I wouldn't suggest trying to replicate that with air tools, not going to be accurate. I'm guessing your using an impact wrench to turn over the engine?
With a leak down test you are compressing air into the cylinder with the valves closed (TDC) and finding the % leaking. It can be done on a cold engine and will provide you with an accurate assessment of your engines overall health.
Here is a good article on how leak down tests work:
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/viewall.html
Here is another good article on variances between different leak down testers and how to interpret the numbers you are seeing during a leak down test:
http://www.hotrod.com/techarticles/engine/hrdp_1203_budget_leakdown_testers_tested/viewall.html
