TwinTurbo.NET: Nissan 300ZX forum - Compression on an old motor is a gamble ..
Subject Compression on an old motor is a gamble ..
Posted by Cjw3 on April 29, 2013 at 7:54 PM
  This message has been viewed 282 times.
In Reply To Re: Do a leak down test. posted by hatchet502 on April 29, 2013 at 06:35 PM
Message If the Engine has not run, then LIKELY you will have rust on Valve and Cylinder surfaces. The results will be different than if the Engine was run only a week ago.. so in my opinion, the numbers will not mean much..
If it was my motor, I'd yank it apart, and re-ring and bearing.. Nice time to take a Peek at things.. And this will allow you spend more money and time that you had originally planned .. as most builds do.. :)
But this is your Build.. so you do what you are comfortable with..
Cj
