TwinTurbo.NET: Nissan 300ZX forum - I'd check the O2 sensors first
aliaZ
on April 29, 2013 at 7:11 AM
Excessive fuel consumption under normal driving conditions
posted by LJZTT
on April 29, 2013 at 06:23 AM
I'd also check the ECU engine temp reading, which is different than what is displayed on your dash. If your engine is running too cool (whether actual or instrumentation error) you will never get out of the cold-start enrichment map
06:23:16 04/29/13
I'd check the O2 sensors first -
aliaZ
07:11:29 04/29/13
I cant recall exactly what temps DataScan showed
03:44:10 05/01/13
Interesting that you and I are having similar issues with
Evan_Wright (Ca)
10:14:57 04/29/13
Also, I put brand new oem oxygen sensors and bkr7eix plugs
Evan_Wright (Ca)
11:56:39 04/29/13
worn CAS issue is partially fixed
03:41:07 05/01/13
I cant say for sure, if I do, it is slight enough that *I*
03:46:22 05/01/13
I agree with aliaZ
300ZMang
10:34:43 04/29/13
