TwinTurbo.NET: Nissan 300ZX forum - Excessive fuel consumption under normal driving conditions
Subject Excessive fuel consumption under normal driving conditions
Posted by LJZTT on April 29, 2013 at 6:23 AM
  This message has been viewed 489 times.
Message Minimal boosting, if at all, no WOT.
Today my fuel light came on at 180 miles.
The OEM gauge read 3/4 full @ 75 miles....I realize the OEM gauge may not be linear and I have confirmed several times over the years that my fuel light illuminates with roughly 5 gallons left.
This indicates roughly 12 mpg. About 4 years ago on a JWT EPROM and stock injectors with single intake, I was seeing well over 20 mpg, sometimes as high as 22-24 mpg.
So how can this happen? There can only be two possibilities right? Software vs hardware
I plan to have the tune looked at soon, but I have good reason to believe that while it may be on the conservative side, it is not responsible for THIS level of fuel consumption.
Hardware variables I have checked:
compression-----4 cylinders @150 or 155(one @160, and one @140)
fuel filter-----relativley new (less than 15k) OEM
air filters-----new
vacuum/boost leaks-----checked and none
injectors-----new Nismo 740's
gas cap-----on tight
fuel lines----I cannot smell fuel at all with car idling in garage after a drive, and all lines in the engine bay check out good
base timing-----set to 15 degrees, ecu timing also at 15 degrees at warm idle
MAF sensor-----voltage checks good in DataScan
What else could I be missing?
Fuel leak somewhere between fuel filler cap and engine bay?
O2 sensors? Mine may be original. I don't recall ever replacing. Should this matter once the car is at operating temp? Or do I have it backwards?
Anyone else had a similar experience and manage to resolve it?
"What a curiosity our new political correctness has made of our public spaces. Let your sex tape loose on the Internet and
be rewarded with your own TV show; photograph a crucifix in a jar of urine and our museums will vie to exhibit it; occupy someone else’s
property and you will be hailed by the president for your keen social conscience. But call people who blow up, behead, and mutilate, “savage” —
and polite society will find you offensive."
--Jared Silverman
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
--Winston Churchill
"When the people find that they can vote themselves money, that will herald the end of the republic."
--Benjamin Franklin
"The last official act of any government is to loot the treasury."
--George Washington
END THE FED
....learn why, in 42 minutes
Full Pardon for PFC Bradley Manning
