TwinTurbo.NET: Nissan 300ZX forum - Late engine compression test
Subject Late engine compression test
Posted by hatchet502 on April 29, 2013 at 2:12 AM
  This message has been viewed 375 times.
Message Ok, so I have a bit of a set back on my build depending on this thread. In short I purchased a Z32TT as a project and have been building it since this last fall. Engine is removed, and has been oil drained for a few months now. I had a few upgrades in line, but I was smart enough to not do a compression test on the motor until now, months later, engine pulled and oil drained. I want to upgrade some major parts like turbos, intercoolers, injectors, ect. I failed to do a compression test like an idiot before pulling the engine but these thins do happen to a 1st timer. So is there a correct way to check compression on a VG motor that has been sitting, no oil for about 3-4 months? I know squirting oil into the cylinder will work, but i don't want a high or off reading. Should I just though new rings in or leave it and build a new long block to through in later?
I need some reliable opinion. Thanks for the help...
